Ana içeriğe geç
Apple Watch Series 1, 7 Eylül 2016'da duyurulan orijinal Apple Watch'un yenilenmiş bir versiyonudur. Parçaların çoğu Series 2 ile aynıdır.
Knocked watch screen loose
Hi,
I bumped my Apple Watch Series 1 and knocked the screen loose. The screen is still connected to the watch (by a ribbon cable) and the watch still works (at least as far as I can determine). I have tried very gently pressing the screen back into place but it won’t stay. I checked with a local repair shop that I’ve dealt with before; they are honest and knowledgeable. They don’t do or recommend 3rd party repairs on Apple Watches because Apple Watches are intended to have a certain amount of water resistance, once that is broken, it's recommended that the whole device is replaced. They are not trying to sell me a Watch, but they are suggesting I purchase a new or refurbished one. (BTW, the watch is out of warranty)
So, after having searched your site, I’m guessing there’s no way to replace the adhesive that secures the screen without disassembling the watch first? The disassembly process looks complex and delicate (which isn’t surprising, of course).
Thanks in advance for any input/suggestions/advice.
Harrison
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I’ll address the claims of water resistance first. Any time a device is opened (phone, watch, tablet), in most cases, yes, this will affect the water resistance of the device. I’ve never heard of claims that these devices are recommended to be replaced after the seal is broken. Sounds like something Apple wants consumers to think so they can sell you a new watch. Of course, the newer watches are designed so that you can swim with them. In this case, I can see the logic. I definitely would not recommend swimming with the watch after a screen replacement. The first generation to my knowledge was not designed for this anyway.
With that said, I have seen some watches come back to our shop because the adhesive didn’t take very well. This might be more of a problem with the force touch sensor coming loose however. The screen sits on top of the sensor and our thought is that if the sensor is loose, the screen won’t stay on very well.
Second, you’re completely correct. There is no easy way to get new adhesive on the device without taking the watch apart. This is one giant pain in the rear especially since Apple had to design the worst system for how the screen attaches. If you look at the guides, they place a bracket over the connectors. I kid you not, I spent about 20 minutes just the other day trying to remove the clip and I’m a pretty seasoned tech. I can only imagine what it would be like for a novice.
If this watch come into our store it’s something we would repair but honestly, with it being a series 1, my recommendation would be to honestly purchase a newer watch. The battery is likely not great and needs to be replaced and once you factor that in plus it’s age, it’s probably worth the upgrade.
Also, just a note about Apple watches. If you break the screen, it’s almost worth just purchasing a new watch. In most cases, the repairs cost about as much as a new watch. If you find a shop that has a low ball price, I would question it.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
[image|2663063]
[image|2663061]
[image|2663064]
tarafından
Yorum Ekle
Yanıtını ekle
Harrison Bolter sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 2,245
