Ana içeriğe geç
A 15.6" laptop by Lenovo from 2013.
Memory test failure, fix and some questions
Overnight my B590 developed a memory fault.
On boot up, a single long beep, and the machine would drop into the bios. Upon running the inbuilt memory diagnostics, I found that values being written during the test were coming back with a single bit always set to 1.
Did usual reseating of the DIMM, changed the DIMM location, swapped the DIMM with a new module. Same error, indicating that this was probably a motherboard issue.
Ran memtest86 (4 passes) from a USB drive with no errors. On rebooting, Windows started up as usual.
Q1: Why did this work? I can only speculate the memtest somehow cleared the stuck bit on the motherboard. Bad capacitor?
Q2: Is this problem likely to resurface?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I would just wait and see.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Hello, my theory behind this issue is dust in the first place, and by changing and replacing the DIMMs you had to move your laptop upside-down multiple times which might cleared the dust and the memtest86 was just a lucky step.
If this happen again, don’t move your computer, try to run it normally multiple times to make sure the problem happen at 100% and then run a memory test, if it works then it’s a software issue if not then it’s a hardware.
Puan 1
Yorum Ekle
Yanıtını ekle
Sanjay Mehta sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 2,828
