Ana içeriğe geç
2008 yılından itibaren Hewlett-Packard tarafından üretilen ve 17,3 inç diyagonal ekrana sahip HP Pavilion dv7 dizüstü bilgisayarları için onarım rehberleri ve sorun giderme bilgileri.
fv 274 av dc jack
I have a dv 7 fv 274 av and think it may be the problem and want to make sure not to get the wrong part . When plugged in if I play around I can get a light showing it is on and charging, the slightest movement and the light goes out. If I try to power it up the light goes out, When I don’t touch it and the light goes on the battery charge but not completely. Somehow the os is now corrupted and I can not get the computer to stay on long enough to do a repair of the system. My thought was a correct replacement of the jack might lead to be able to use the machine again.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
murohyg27 this sentence in your description “When plugged in if I play around I can get a light showing it is on and charging, the slightest movement and the light goes out. If I try to power it up the light goes out “ would lead me to changing the DC in jack first. This video should be pretty similar to your system. Of course, you can download the service manual from here
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
murphyg27 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 249
