Ana içeriğe geç
Fare, klavye ve monitör gibi çalışması için gereken üçüncül bileşenlerin dışında ana bileşenleri ayrı bir kasada bulunan, sabit, kişisel masaüstü bilgisayar.
542 Soru Tümünü görüntüle
New build, reboot and select new media
Motherboard: ASUS AM4 TUF Gaming X570-Plus (Wi-Fi) ATX Motherboard
Graphics card: nvidia 1080 (will be replacing when 3080 is in stock)
Proccessor: AMD RYZEN 7 3700X 8-Core 3.6 GHz
Ram: 4'x CORSAIR Vengeance RGB Pro 16GB
Power supply: 750W Corsair
Storage: 2x 500GB, 1x 3TB
This is my first computer I've built, I'm have a problem with the the computer saying it has no boot media, the 2 500GB drives where both from my old computer I had and it worked perfectly fine. I've tried clear the key management, playing with what Hard drive it was booting off, tried moving cables.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
What OS are you installing on it? Does it not detect it in the BiOS or in the OS install screen?
tarafından
I'm running windows and I believe it registers
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
It sounds like you need to create or buy an installation media.
The link I am providing will allow you to create a USB install drive from another computer. Once that is created it will allow you to install Windows 10. Although, because this is a new build, you may not be able to use the key you had from the previous computer. Windows 10 will still work, but it will tell you that it is not genuine until you either buy a new activation key, or sometimes you can contact them and they'll allow you to reactivate the key from the previous computer. (Sometimes)
Also, installing Windows will wipe whatever is on that drive, so please make sure you install in on the intended blank drive.
https://support.microsoft.com/en-us/help...
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
I tried the USB with the link you provided but It didn't work so I believe I did it incorrectly
tarafından
Its currently taking me in a infinite loop of copying windows 10 to one of my drives
tarafından
they changed the process a little since the last time I created an install drive. When you copied the Windows ISO to the drive, did you burn it or did you copy it?
tarafından
Yorum Ekle
Yanıtını ekle
Issahia Farley sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 82
