2001 yılında piyasaya sürülen, buz sebili olmayan, yoğuşma önleyici rezistans anahtarına sahip üst donduruculu bir model olan Whirlpool ET8CHM*K*0* buzdolabı için onarım ve bilgi rehberi. Bu sayfa, ET8CHM*K*0* düzeniyle eşleşen model numaraları için bilgiler içerir.
Whirlpool et8chmxkb04 defrosts for a while then I can't get it to work
Can someone please help. My whirpool fridge coils freeze up and the heater won’t turn on to thaw them. I replaced the thermostat, heater, timer twice, wiring harness, fan motor unit. It seems to work after I see a spark while connecting the heater wires temporarily (yeah I know it should be unplugged). It defrosts for a week or two (sometimes less) then I can't get it to work? Why would it work for a while after sparking? Thanks for any help I've been messing with this thing for a while now, years. Its a whirpool with the freezer on the top from 2004. The fridge is model number ET8CHMXKB04.
Initially it may be safer to use an Ohmmeter to check for continuity in the wiring from the heater’s harness connection.
Disconnect the power from the fridge and then disconnect the heater from the wiring harness and test the wires that are coming to the heater, not the wires from the heater.
I cannot find a wiring diagram or a service manual for your model but here’s an image that has two circuits that show how it might be wired. I’ve drawn in arrow points where to connect the Ohmmeter. It tests the wiring path between the components and the supply
As I said it might be the same or similar to your model, but then again maybe not. Check what colours the wires are as that may also help to identify if it might be the wire you need to connect to with the meter. The Neutral wire should be white or grey. As for the others they are shown on the diagrams but they may be different in your model.
If either wiring diagram is not similar then you will have to connect the Voltmeter in place of the heater (or between the heater and earth with the heater still connected) and check.
Turn off the power and jam the meter leads in the heater harness plug connector so that you don’t have to be holding them and then turn on the power. Turn off the power before touching them again.
Unfortunately, I don’t know how to force a defrost cycle in your model so I don’t know how long you’d have to wait before it enters the defrost cycle so that you can test
(click on image to enlarge for better viewing)
I realize that you said that you replaced the defrost thermostat but here’s a video that shows how to test if one is OK and it also has good information about how to find out at what temperature they release and then re-operate, as the defrost thermostat does play a big part in the heater operate circuit.
In the circuit on the left it actually closes and opens the heater circuit so the timer can still cause a defrost cycle to commence and cease but there may not be a heater circuit. In the one on the right it opens the timer and the heater circuit so if the timer has no power then there will never be a defrost cycle.
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
9 Yorum:
Yes part #32 is it. I have not checked the compressor overload protector or start relay. I didn't think those had anything to do with the unit not defrosting? Can you explain please. thanks
When you said "It defrosts for a while then I can't get it to work? " I was thinking that it did start to defrost and when the thermostat operated to signal the end of the defrost cycle, the timer should turn on the compressor again and it didn't start. maybe I misunderstood
No worries I think I understand what you meant now ;-)
Did you use a Voltmeter to check if the power is there for the heater for the required full amount of time for the defrost cycle? Be safety aware as usually it will be full mains supply voltage i.e. 120V AC
If it is just wondering if the drain tube was blocked preventing the meltwater from draining to the evap pan under the fridge, therefore ice will buildup when the compressor is restarted and the meltwater refreezes again
