Ana içeriğe geç
Ters ozmoz üniteleri, mutfaklarda lavabo altlarında bulunan yaygın su filtreleme çözümleridir.
Why is my water filter so low?
We have a Profile Reverse Osmosis Water filter in our sink as a water softener. We recently saw a problem with the water speed as the flow rate decreases after a couple seconds to a drip. I was thinking we might have to reset the filter but Im still not sure. Do you guys have any tips to fix this issue? Thanks in advance!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi , check to see if the tank is full , if it is and the water flow cuts off chances are that there is a problem with you tank blatter and will need to replace the tank. there is a valve located on the side of the tank and pressure should be around 6-7 pounds. Granted the r o will produce soft product water but if your wanting the whole house water softened a water conditioner softener is the solution, ro is usually used at point of use ex. kitchen sink whereas the softener is a point of entry system servicing the whole home.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Suchit Bandaram sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 533
