Left speaker only working intermittently, crackling noise with ANC
Hello good repair-inclined folks,
Recently, my Bose QC35 headphones have developed an annoying fault. At first, I noticed a crackling sound in the left speaker, which is motion-sensitive and linked to active noise cancelling (no ANC, no crackling). Later that day the left speaker kept dropping out.
Has anyone dealt with this? Is the driver shot? Any repair advice would be appreciated.
Thanks!
Bu iyi bir soru mu?
2 Yorum
My bose headphone one side not working with bluetooth however its working fine with wire.
PS DM tarafından
I ended up replacing the driver. As suggested in a comment below. That fixed the problem.
I think Bose does not use prime quality of drivers in the headphones or drives them too hard and hence they die early.
I tried to find the original Bose parts -- no chance. They might just buy cheap ones and match their digital processing to match the driver. Who knows.
In the end, I just ordered a pair off Amazon with decent reviews (40mm, 32Ohms, if you like search for Bose QC35). I don't presume to be able to judge whether the headphones now sound worse or better.
The glue that holds the speaker enclosure and the driver itself in place is some mean stuff. I don't have a hot-air soldering iron and thought a hair-driver would do. Weeeell, yes, but it is incredibly hard to pry the enclosure off without also mangling some of the plastic. I will have to live with some dents in my headphones now. Scraping all the glue off; hard work. I wish they used a less grabby adhesive and some screws instead.
Mike tarafından
