Valve clearance specification for Briggs and Stratton 6HP OHV engine
Hi. I have a pressure washer with a 6HP overhead valve Briggs and Stratton engine on it. (vertical shaft). The engine code is 120612-0132-E1. What are the specs for the valve clearance for this engine? Thanks!
Bu iyi bir soru mu?
Puan
0
You'll need the engine model number (diffrerent from the engine code). I suggest you start at <https://www.small-engine-projects.com/br...> for the info you need. The engine model number is not always easy to find. Check <https://www.briggsandstratton.com/na/en_...> for that info. Sometimes they'll have a QR code on the label that has the engine code. If you read that with your cell phone, it will tell you the engine model. Good Luck!
moe_r tarafından
