Ana içeriğe geç
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Soru Tümünü görüntüle
Just Changed the Battery, But now rebooting
I have just switched the original battery for a new battery, however several issues are now occurring:
1) With out external power it will not start up
2) With external power it reboots constantly
3) It shows it at 100% charge
4) It says connect to itunes
I am going to try to but the old battery back in again, i tried once before and i had similar issue.
Any suggestions?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you have checked your connections for dock (no.4) and the 2 screws over the battery (1 under the do not remove sticker) are on properly and securely then it may be the old "battery incompatibilty" problem that is common to iphone 3GS. If you connect to itunes and attempt restore do you get error 29? then this would confirm the battery as the problem.try the old battery and see what happens. Why did you replace the battery..was it doing this before you replaced?
Bu yanıt yardımcı oldu mu?
Puan 5
Yorum Ekle
wrong battery type, find other exactly for 3GS , i had same when i used 3G battery advertised as 3GS compatible. Random restarts every 2-3 minutes, error 29 etc..
Puan 1
Yorum Ekle
Yanıtını ekle
MasterEnigma sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 870
