Replaced my battery, however, all LED lights are now illuminated
After some quick diagnostics resulting from a battery that would no longer charge (flashing red power LED) when charging adapter connected, I figured the battery was shot and would no longer charge as the voltage was likely below the system threshold.
After installing a new battery ordered from ifixit, all of the LED lights come on. When I plug in the power adapter, the battery does not appear to be charging and ll light remain illuminated until I remove the battery.
Bu iyi bir soru mu?
2 Yorum
@codyandresen have you double checked your work? Everything properly connected? Wiring looks okay etc.?
oldturkey03 tarafından
All work has been checked and properly connected. I'm wondering if this issue is due to a malfunction with a component on the PCB?
Cody Andresen tarafından
