SD Memory Card maximum
What is the maximum size SD memory card the Canon PowerShot A580 IS will accept?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
According to the User Manual your camera accepts SD memory card/SDHC memory card/MMC Card/MMCplus card/HC MMC plus card. This means you could probably use a 32GB card. I do believe that most people do not go higher than 8GB to prevent read/write errors and buffer overflow etc.
Bu yanıt yardımcı oldu mu?
My 590 is keeps saying memory card error and won't do anythinng what is the problem?
Hi brianshackelford607,
Have you tried a different SD Card?
Try using a card reader connected to a PC to verify if your SD Card is still OK or if there is a problem with the camera
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 4,698
