Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 Soru Tümünü görüntüle
MacBook Pro A1398 No backlight
hello, so the macbok does not have a backlight, it works fine via HDMI.
i have checked the board and found a blown fuse, replaced it and its still the same,
i have checked the LVDS cable and i can see that pin 1 and 2 on the retina screen connector are damaged..
can this cause the backlight not to work??
Bu iyi bir soru mu?
Puan 0
1 Yorum
i have replaced the connector on the display and it works now, thanks!!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Clearly you’ve got a messed up T-CON board within the display assembly!
Here’s a snippet of your display connector. FYI: Its miss-marked as LVDS the connection is technically iDP
It might be a bad connector or the T-CON board its self. Its very easy to damage the panel and the T-CON board. Best to just replace the full display assembly.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Hello, thanks for the answer, I was looking for this schematic everywhere!
tarafından
Yorum Ekle
Yanıtını ekle
jozef horvath sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 495
