Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
iPhone stops charging after a week of not being used
So I have an Iphone5s that stops charging after not being used for a while. I at first thought it was the battery so I replaced the battery and it charged fine, then I put it away for a week and it stopped charging. help?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi madmikeizcool,
Looks like a common issue with trystar. A chip on the motherboard when faulty fails to charge dead/discharged batteries. Not worth fixing at this point in my opinion. Just get a new 5s or even 6s, would probably still cost you less
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
may be battery got drain so thats why your mobile is not showing any sign, in this case plugin charger for while ( 1 hour) even its not showing any sign,
second thing is as you said week ago you replaced battery it may be battery fault, contact the dealer or seller you bought from.
above information provided by ``krishna online store``
Puan 0
Yorum Ekle
Yanıtını ekle
madmikeizcool sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 44
