Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
flashing red light of death
I was up dating Was able to get dvd out took apart drive know problem but cant get rid of light flashing
Could it be same problem as yellow light problem?
cleaned unit up
Bu iyi bir soru mu?
Puan 0
1 Yorum
so i have to get the hard drive out and put it back in
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This could be a faulty power supply, dead hard drive or malfunctioning CPU. further trouble shooting will be required. First thing I'd do is to disconnect everything for right now, including video cables, controller cables hdmi cables etc. this will rule out any loose connections. Then reset the cables. Try resetting your console- Place your console in standby mode (when it shows the red light) then press and hold the power button until you hear 2 beeps. This will reset your console settings however it COULD affect your hard drive data.
Try taking out the hard drive and putting it back in. The instructions to do this are in your user's man Let the console totally cool down. These are just to name a few. I do have a bit of a repair manual that you can download for free :-) from here you may also want to check this video I do hope this will help you out. Good Luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
craig sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 1,291
