Ana içeriğe geç
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Soru Tümünü görüntüle
Why my computer has 9 beeps and the display led doesn’t turn on
i bought a broken imac from 2007 and when i turned it on it make 9 beeps when i opened it i realized that only three leds were lit except the led on the LCD how can i fix this problem?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
1 beep = no RAM installed
2 beeps = incompatible RAM types
3 beeps = no good banks
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
5 beeps = processor is not usable.
You are most likely hearing a series of 3 beeps a pause then 3 beeps, a pause, then 3 more beeps
Check the RAM modules to make sure that they didn't become dislodged. There is a possibility that the DIM slots are very dusty too. Try blowing out all dust from the computer.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I already did it but it didn’t work .
tarafından
Interesting, never knew about the 2, 4 and 5 beeps. I'm assuming the latter is for iMacs where you can replace the processor.
tarafından
Yorum Ekle
9 beeps in an SOS pattern (. . . _ _ _ . . .), a pause, then it repeating again usually means the EFI ROM is corrupted and the computer is in EFI ROM recovery mode. Give it a good hour to try and let the computer save itself.
If you think you’ve waited long enough and it still hasn’t done anything, since you have a pre-2011 Mac, you should be able to replace the chip containing the EFI and the EFI ROM. I have no idea where to get one, unfortunately.
Puan 0
Yorum Ekle
Yanıtını ekle
Matheus silva nascimento sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 271
