Ana içeriğe geç
Repair information for Sharp televisions.
105 Soru Tümünü görüntüle
Display lights up then goes dark
I have a Sharp LC-60LE832U TV. The screen went black suddenly while viewing one day. The console light (white V in bottom of bezel) was flashing one long and one short indicating a lamp error. I performed the “Input + Vol -” procedure to turn the TV on. The backlight comes on for just a second then goes dark. When I do a flashlight test I can see the service menu. How should I proceed? Does this sound like the power supply? backlight array? Is this something I could test with a multimeter to determine and what steps would it entail? I am an IT professional with a lot of experience under the hood of electronic hardware.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@rcm907 since you can see the menu etc. with a flashlight it is your backlight that has failed. Most commonly would be a failed backlight strip. Of course you always want to check the voltage going to your backlight LED’s but…..be prepared to change the backlight strip
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Robert McDaniel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 416
