Where is the egr valve located on 1998 mazda 626
where is the egr valve located on 1998 mazda 626
Bu iyi bir soru mu?
Bu iyi bir soru mu?
It's underneath the throttle body. Round in shape, has an electrical connector for the EGR lift sensor and a vacuum line is connected to it. Check the attached diagram. I would definitely clean it first and make sure that your vacuum lines do not have a leak before replacing it. No a common part that wears out. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 5,001
1 Yorum
Thank you for accepting my answer and good luck to you.
oldturkey03 tarafından
