Ice maker On and Fridge Off lithts are blinking.
Hi All,
I have problem with my Samsung RT18M fridge (it’s type B with no ice maker installed). The two indicators of ICE MAKER ON and Fridge OFF are blinking after plugged in the power.
I turned off bottom fridge and switched top freezer into fridge for a couple hours.
I unplugged the fridge, removed everything in it, disassembled the doors, did cleaning , then moved upstairs.
I got this problem after I assembled the doors back and plugged into the power.
- the two lights keep blinking.
- no reaction when pressing the buttons except the Sabbath Mode.
- It will beep when leaving the door open,
- Compressor is working. Top freezer temperature is maintained arount 2-3
°C (it’s like in Fridge mode) and Bottom Fridge is about 13 °C (it’s like in OFF mode).
- The inverter light is on when the compressor is running. So assuming the inverter board is good.
- Contacted Samsung customer service, tried unplugged the power, disconnected the circuit board connectors, etc. none of them worked.
Bu iyi bir soru mu?
