Ana içeriğe geç
The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
313 Soru Tümünü görüntüle
Why is my fan is always running at 7200RPM
My macbook fan is always running at 7000-7200 RPM. From the moment, I press the power button, it starts running very loud, and stays the same. It doesn’t matter what I am doing, it always stays around 7100RPM. I’ve reset de PRAM and the SMC. I’ve installed Fanny and it says:
Fan: #1
Current: 7104 RPM
Min: 1200 RPM
Max: 6500 RPM
Target: 1200 RPM
CPU: 34.75 degrees celcius
GPU: 36.00 degrees celcius
Please help me fix it, the sound of 7200RPM is very loud and annoying.
Update (11/04/2020)
Here is the screenshot.
https://pasteboard.co/JyPPvth.jpg
Please let me know if it doesn't work
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
7 Yorum:
Did you try running the onboard diagnostics to see if an error code? Restart the system and press the D key to enter. Tell us what it is.
Reference: Mac startup key combinations
tarafından
@danj Thanks for your help. I have already tried that and nothing comes up.
tarafından
To be clear you don't get any errors Or it doesn't work?
tarafından
Pardon me, I don't get any errors. Sidenote: I've already replaced the thermal paste and cleaned the fans thoroughly.
tarafından
OK, lets do this, kill Fanny and install this app TG Pro it will offer a better view of the thermal sensors.
tarafından
2 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Here’s the needed part MacBook Air 13" (Late 2010-2017) Fan and here’s the guide MacBook Air 13" Early 2014 Fan Replacement
MacBook Air 13" (Late 2010-2017) Fan Görseli
Ürün
$29.99
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
So do you think it's just a faulty fan? Could a faulty fan choose for itself to run 7200RPM? I would've thought the fan would only follow instructions from the motherboard (like the motherboard would say go run at 7200RPM)
tarafından
Well ... It does get told to speed up and slow down but what if the information to the logic board on what the fan speed is is gone? Think what would happen if you lost your speedometer in your car. What do you tell the police officer when you get pulled over, here the system is designed to assume the worse and ramp up the fan to make sure the system is being cooled.
tarafından
Thanks for your help, I will order in the new part and let you know if my problem has been fixed.
tarafından
Yorum Ekle
Yanıtını ekle
Tom sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 15
Her zaman: 513
