Ana içeriğe geç
A mid-range smartphone from Samsung released in 2019.
Will device boot with no battery?
Hey, i was taking a look at a phone for someone who said it wont charge or turn on.
When plugged in a lighting bolt in a circle appears but no battery percentage. i took apart the phone and disconnected the battery then plugged in the charger and same thing
Lighting bolt in a circle with no battery percentage
Does this mean the battery is the problem? The device in theory should boot without one while plugged in like a laptop.
Would this mean the issue is software and not hardware since the charging port is working.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Austin Sidman this “ i took apart the phone and disconnected the battery then plugged in the charger and same thing. Lighting bolt in a circle with no battery percentage” makes the battery the prime suspect. Replace the battery then re-evaluate. There are multiple other board level hardware issues that could cause this but start in an orderly fashion so as to not try to change/repair parts that don’t need to be replaced/fixed.
Samsung Galaxy A50 Battery Replacement
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
It could be software related, but to me it rather sounds like a problem with the part of the circuit that charges the phone (or the battery itself).
It is with some phones possible to boot without a battery depending on the amount of power the phone consumes, and the chargers ability to provide this power.
Puan 0
Yorum Ekle
it can work with some devices or with some ways for example with USB, sun energy, or you can use it when you power off it
Puan 0
Yorum Ekle
Yanıtını ekle
Legendslayer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 39
Her zaman: 1,884
