Ana içeriğe geç
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Soru Tümünü görüntüle
How to spot if motherboard has been switched?
Some weeks ago I went to a local Mac repair shop because of some dropped liquid... after some inspections on the damaged modules they said that the only damages were in the wi-fi and the disk, now they are saying that the motherboard is also damaged. I am suspicious because of some shady moves these people made. Now they are giving me back my Mac Air.
This is my question: Is there a way to know if the motherboard they are returning me the mac with is the same as the one I always had? I think they might have switched motherboards...
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The simple way is to open the About this Mac dialog box locating the systems specs and the systems S/N which is part of the logic board. Compare it to the bottom covers S/N they should match. I would also look at your repair tag as the S/N on their paperwork should have been the cases and lastly your original receipt from Apple (Paper or email) will also have the original S/N of the system.
Besides the S/N you should be able to compare the specs of your purchase and what your system currently has.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thank you for your answer!
I will use this other mac to look for the data in the cloud because currently, I can't turn on the one with the issue.
So the S/N printed in the logic board should mirror match with the device S/N in the bottom cover or is slightly different?
tarafından
@Michel - Oh No! The system is dead? The logic board printed S/N is not the same!
I would talking about what you see in About this Mac as you are accessing the firmware S/N. The printed number will include the spec type but thats not the same thing as the firmware S/N, the printed logic board S/N which is not the same.
tarafından
Yorum Ekle
Yanıtını ekle
Michel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 241
