Ana içeriğe geç
battery replacement screen stopped working
Replaced the battery, phone worked for a couple days, then screen started to malfunction. Took phone apart, checked logic connections, phone worked again for a few days, then same problem with touch screen not working/unresponsive. Took apart again, checked logic/screen connections and phone is now non-functional/scrambled screen only. Can I replace any of these connectors or is the phone aced?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Unfortunately I’ve had this to me a few times after a battery replacement and 9/10 it always comes to the touch ic chip on the board. If you can replace yourself, cheap fix otherwise if you have to take to a repair shop they usually will tell you to upgrade as it isn’t worth the repair as it is a very common fault.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Dirty Perry sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 61
