Face ID and phone restarting
My 11 pro Max phone is restarting every 3 mints water it got damage by liquid and Face ID is not working except tht 2 everything is working good
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The first thing to try would be a battery replacement followed by the dock connector. These are the main two reasons the phone would restart every few minutes.
Bu yanıt yardımcı oldu mu?
I have had a iPhone 7 Plus in the past that had water damage and a similar problem of frequently shutting off and the home button not working. I would recommend fully shutting down the iPhone, removing the SIM card tray, and leaving it in an open air environment to dry out for about a week or two. This usually dries out the components and I was able to get the iPhone to stop restarting and get the home button working again. You could try to blow dry the phone on a low heat setting, but this should be a last resort. Rice and silica packs do not work very well for liquid damage.
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 27
Her zaman: 512
1 Yorum
Did you eventually fix your problem??
Roman Alifanov tarafından
