Ana içeriğe geç
The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
140 Soru Tümünü görüntüle
Not able to power on - get fan spin with SMC bypass
Machine was unable to power on. I tried an SMC reset, and the charger light changed so I know it went through and that the power button works, but the machine still couldn’t power on. I tried a separate battery that was known to work and had some charge on it, and I still wasn’t able to power on.
I confirmed the MagSafe 2 board was passing the correct voltage. I even took the machine to a sort of minimal configuration by disconnecting components from the logic board. At no point would it power on. I eventually tried an SMC bypass and this caused the fan to spin but there were no other signs of life (no data on display, CAPS lock key didn’t light).
Also there are no signs of corrosion on the logic board or other components. Anyway, I’m just wondering what other steps I can take! Thank you.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sadly, it sounds like the logic board has failed something within the CPU logic area. Could be a simple cap issue or the VRM FET’s are messed up.
You’ll need to breakout the schematics and board views to trace out the logic or just replace it.
But! Given the costs it might be wiser to just get a newer (used) system which supports more than 8 GB of RAM which is the limit in this series.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Zach sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 471
