Ana içeriğe geç
Panasonic Lumix DMC-FZ1000, 27 Temmuz 2014'te Panasonic tarafından piyasaya sürülen, döner ekranlı bir dijital objektifli fotoğraf makinesidir.
Grinding Noise - Non-operable
My FZ1000 makes a grinding noise when I turn it on. It doesn’t do anything besides that annoying noise, as if it’s locked up.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
This sounds like the problem I had which I was able to repair.
In my case the problem was that the screws securing the zoom motor loosened, allowing the worm gear to skip while turning.
Solution was to tighten those 2 screws INSIDE the zoom motor assembly.
Step 22 of the disassembly guide shows removal of the zoom motor assembly. If you can feel play between the motor and the zoom motor assembly case, it's the same problem.
The zoom motor assembly case must be opened to reach these two screws.
Resim
Search my username on DPReview, I have a public gallery with photos of the repair.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Yolanda sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 41
Her zaman: 336
