Ana içeriğe geç
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
Home button / battery fire
Changed battery on my cousin’s 6s plus ….. it was damaged and actually caught on fire when removing it. I quickly got it out of phone , it appeared not to do too much damage. Some scorching in the left corner around and on headphone jack . I cleaned it up put new battery in , put it back together powered up everything worked EXECPT home button ….. top screen / home button was not on/near battery when it caught on fire … do I need to change charging port / headphone jack assembly….. or something else like change the entire back assembly of the phone . Need some ideas or help on what direction to go
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If you didn’t remove the actual home button I would make sure the connector is seated properly. If it is than you have most likely damaged the flex cable or nudged a tiny component around the connector. If it is a damaged flex you will need to replace the screen.
The charge dock has nothing to do with the home button.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Thanks, Chris …..The reason I asked about the port and the surrounding area is , because in reading one of the other posts , talking about the home button , someone mentioned a broken or bad ( in my case melted ) connection causing a continuity problem that affected the home button. …. I’ve removed and reconnected everything multiple times. And when the fire took place the screen and button where 4 feet away, so the fire couldn’t have damaged the cables or connectors. Not to say I might have when I removed them with spudger . Is there anything under the headphone jack orTaptic Engine that could cause this issue? Like a ground wire or a ribbon cable …..any or next idea please
Puan 0
Yorum Ekle
Yanıtını ekle
Joe Hoy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 104
