Ana içeriğe geç
Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
140 Soru Tümünü görüntüle
Startup Chime but no image, stuck on a white screen.
Hi all,
I just started learning about MacBook logic board repairs but came to a halt pretty quick. I am trying to repair a 12” MacBook that does turn on, I hear the chime, and it makes a sound when I plug in the charger, I don’t have an external monitor to use but the guy I got it from told me it worked on an external monitor. I went looking for bad component to find none. After looking at the display connector, it had some wear on it and I decided to replace it. Successfully done so, but left with the same problem. I also tried all the reset methods found on the internet, for NVRAM, PRAM, safe boot. When I tried using some of the key combinations it looked like the computer would instantly turn of and instantly give the chime again, which I thought was suspicious because normally it would take longer to boot up. Is there someone who could nudge me in the right direction what to look for next. I am not a hero with schematics and board views, but I do know the basic a little.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Have you considered the drive? Try using another drive that is confirmed to work either swapping it or attempt to boot using option.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Greetings, have you tried a SMC reset on the machine?
If you have tried all the resets as stated and the SMC reset and etc.
This sounds like a missing PP3v3_LCDVDD_SW issue on the logic board.
This video may help you in your diagnosis.
https://www.youtube.com/watch?v=lc3eArx4...
Cheers!!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Tomas van der Laan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 209
