Ana içeriğe geç
Repair guides and support for your Sanyo TV.
360 Soru Tümünü görüntüle
plugged it and my lights went off, and the TV didn't come on
Hi, I'm Collins, bought this TV and was chipped to Nigeria. Immediately i got it, I plugged it and my lights went off, and the TV didn't come on, later was told it had to be used with a step down, got one and still TV didn't come on. No standby lights, no signal at all.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @ubias
Did you get the TV fixed after it was plugged in and it turned off all the lights, you didn’t say?
When the higher voltage power supply was connected to the TV which requires a lower voltage supply to work it would have damaged the power board in the TV. It definitely would have blown a fuse on the board and probably also damaged some other components as well. Connecting it to a step down power supply now would have no effect as the TV is damaged and needs to be repaired first, then you can use it connected via the step down power supply.
If you don’t know much about electronics you may have to get a reputable, professional TV repair service to fix it for you.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Chuks sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 33
