Ana içeriğe geç
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
151 Soru Tümünü görüntüle
Unresponsive band in screen after digitizer replacement
I just performed a digitizer swap on a very badly cracked iPad 6th gen. After reassembling everything, I crossed my fingers and cheered as it turned on, then again after I found the touch screen was responsive. However, upon trying to enter my passcode, I realized that there is a horizontal band across the screen that does not recognize any touch, infuriatingly in the same place as the top row of numbers. How do I fix this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
hello Joel,
unfortunately, it is often talked about. There are many reasons why touch after replacement does not work partially. Most often it is a badly positioned connector in the proper port. The connection is mechanical and sometimes fails. Clean them and make sure all copper pins are in place. The second common reason is that the digitizer was damaged at the factory or during assembly. Of the 100 bought, over 15% are often damaged, while damage during assembly occurs on the edges of the signal tapes, along the main paths - at the edge of the contact with the housing. A abrasion is enough to turn off the entire section. Good luck.
  • regards,
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Joel O. sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 283
