Ana içeriğe geç
Repair guides for displays (or monitors) for computers or other devices with video output.
505 Soru Tümünü görüntüle
What have to my screen? top screen appears at bottom
Can anyone diagnose this problem? I've been trying many methods it doesn't seem to get better, My biggest issue now is how can I call this monitor issue to find the right to fixing it. Is it a hardware or software failure?
Model: Acer g206hql
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
hey man did you find a fix or the cause please let me know
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hello,
Can you post any internal screen and windows settings?
How is it connected? Can you switch cables?
Can you try another device working with the same issues on this monitor?
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Thank you for answering. I swapped the cable(VGA) with my second monitor and the same issue still there so I suspect it might have to do with my monitor hardware or else because the monitor was functioning properly a night before I open it again, thus I've tried without connect the cable the issue remaining
tarafından
So theres no second device (Laptop, another PC) to test on?
Are the outputs both on your GPU? Can you try an on-board motherboard output?
Then maybe your drivers corrupted, maybe uninstall graphic drivers and try again.
tarafından
Yorum Ekle
Yanıtını ekle
Waris Thongkaew sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 578
