Ana içeriğe geç
Batarya yükseltme ve ekran onarım talimatları da dahil olmak üzere, PSP Go için kapsamlı onarım kılavuzu.
PSP Go - No Power, No Charging
Day before yesterday every time I plug in the charger orange light turns on for little while then it turn it self off, now since yesterday my PSP Go doesn't charge, NO orange light and I can't turn it on.
Any word of advice how can I determine what's causing this problem (USB cable, AC adapter, or PSP itself)?
Bu iyi bir soru mu?
Puan 6
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
hold square triangle start select and home and turn it on good luck:)
Bu yanıt yardımcı oldu mu?
Puan 7
4 Yorum:
great thanks really helped ..
tarafından
no it didn`t..
tarafından
I cant believe this worked, after around 9 years of not being able to use my psp go, this helped. PSP GO is like new and i can continue my gaming
tarafından
this trick worked on my psp go that only charged with compatible cables. i tried 2 different original cables and no luck on charging or connecting to pc on usb mode. after the trick works wonders
tarafından
Yorum Ekle
Wolfin2010, check your AC adapter with a multimeter/voltmeter just to make sure it works. Also check your cable and make sure it is not frayed and in good working order. Check the plug on your PSP and make sure it does not have any corrosion or other damage. If all that checks out, I would try a new battery. PSP Go Pil Değişimi after that it is time to reevaluate. If you are really handy, check on here for the fuse location of your go and check your fuses to make sure they are all okay. Hope this will at least get you started. Good Luck
Puan 2
1 Yorum:
Hi I already replaced my battery but am having issues again. Any ideas?
tarafından
Yorum Ekle
Having same problem with my PSP1001 going to try resetting first if that don't work then I will test the charging pin to see if its not making good contact.9 out of 10 times its one of these…..
Puan 0
Yorum Ekle
2019, PSP go hasnt worked since I was a kid (about 10 years ago when I took a trip overseas) and tried this AND IT WORKED. I cant even believe it I'm so excited. Give me your EXACT address so I can come kiss you my good sir
Puan 0
Yorum Ekle
Yanıtını ekle
Wolfin2010 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 22
Son 30 gün: 136
Her zaman: 36,406
