Ana içeriğe geç
A mid-range smartphone from Samsung released in 2019.
Phone won't detect WIFI but Bluetooth work
My phone had water damage (Wifi and bluetooth not worked ) . After had it fix, only Bluetooth worked. My phone could not detect WiFi at all. Is this hardware or software problem?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @khatz ,
If it was professionally repaired take it back and tell them that it is not working properly after they fixed it. They should have tested all the main functions of the phone before handing it back to you.
There are two antennas in the phone so maybe it is a problem with them although Bluetooth and WiFi share the same antennas and also the same IC chip on the board so it is unusual that one works while the other doesn’t unless it is damage that they didn’t fix.
Here’s the ifixit Samsung Galaxy A50 Battery Replacement guide. It is only linked to let you see the blue and white antenna wires in the phone. They can be seen in the image in Step.19 .
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
khat sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 250
