Ana içeriğe geç
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Won't boot all the way up
I am trying to fix this for a friend. It is a white macbook, I don't know for sure whether its an a1181, the writing on the bottom is rubbed off the case. When you hit the power button it will get to different stages of the start process, but it doesn't stop at the same spot consistently. sometimes I can log on and start toying with it, other times it will get to the apple screen and stop, and still other times there will be just nothing. any help will be appreciated, thanks
Bu iyi bir soru mu?
Puan 1
1 Yorum
I don't know if it is related, but I also just fired it up and got it working, but then the backlight went off.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try starting up from your system installation disk, "C" key. Go to the second screen pull down menu to Utilities > Disk Utility. Select your hard drive in the left hand column. Run repair of the drive till it runs clear, then repair your permissions. Let us know your results.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
I tried to do this however I can't because it won't boot off of the disk
tarafından
That's not good. Try it in Target mode with another Intel Mac and a firewire cable.
tarafından
Yorum Ekle
Yanıtını ekle
Trent sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 482
