LG 55ec930v relay clicks twice...no picture
The power board I suspect is ok. I’m thinking the I/O main board is needing reset
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Mike Speed follow the flowchart and measure the voltages. Let us know what you find. If unsure post some good images of your Boards with your QUESTION. that way we can see what you see.
Bu yanıt yardımcı oldu mu?
Ok... I’ve biased the drv and power on via 1k resistors with no I/O board connected. All volts are stable. The system only turns off when I/O board is connected. The relay clicking is the lower left mains input relay.
Mike Speed if your Voltages are as they should be then the issue appears to be your main board.
If there is a fault coming from screen or T-con to main board, the main board will lock itself after 3 failure.
To lock out main board you need to reset it by for example service remote from china.
The result of locking main board will be: you turn on, hear clicking relay - black screen - after 3 sec clicking relay again off.
You need to buy MKJ39170828. Made in China - Factory SVC Remocon. Price about 7 usa dollar.
How reset with MK39170828??? TV is LG55EC930 V
Yes. How do we use this remote to reset the mainboard? You can't just say something like that and then ignore questions on how to use it?
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 91
Her zaman: 1,607
10 Yorum
Mike Speed does the power LED turn on? What exactly happens when you push power on? Have you checked the power board? Which relay is clicking?
oldturkey03 tarafından
Power led stays on for maybe 4 seconds too
Mike Speed tarafından
Will the T con cause the I/O to turn off the power board?
@Mike Speed when you are saying the I/O board, are you referring to the main board? It should not turn it off because of a bad T-con board
:)...I’ll rule out the tcon. I refer to the main green board, some call it I/O. To recap, the green board seems to be turning off the 3.3 v to “power on and drv on”
5 tane daha yorum göster
