Where can I get an antenna converter cable?
My new charging port did not come with an antenna converter cable and my old one is broke. Where can I get a new one from?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Your best bet would be to pull from a donor port. You are talking about the small black antenna soldered to the Charge port correct?
if you were a business you could purchase it from the following area. But, It will at least give you proper naming to buy on ebay. https://www.mobilesentrix.com/wi-fi-ante...
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 242
No, the small flex cable the connects the bluetooth/ wifi antenna to the charging port.
cd70451 tarafından
Ok you talking about the Flex that runs along the Flex Charge Port. Let me see if I can find one
Shawn Blair tarafından
Thank You. I found one on ebay. Here is what I was talking about. https://www.ebay.com/itm/Dock-Connector-...
cd70451 tarafından
