Ana içeriğe geç
Fujifilm X100T, Fujifilm Corporation tarafından 2014 yılının sonlarında piyasaya sürülen, X100 serisinin üçüncü nesil kamerasıdır. Siyah ve gümüş olmak üzere iki renkte gelir ve ön tarafındaki büyük T harfi ile ayırt edilebilir. Wi-Fi özelliğine sahiptir ve 16 megapiksel çözünürlüğünde fotoğraflar çekebilir.
X100 F bottom plate replacement
Hi!
I have to replace the bottom plate od my x100F. I have watched X100T dissesembly guide on this site. It is not clear do I have to peel the leatherette or do I just remove the six screws at the bottom of the camera with the leatherette on. Did anyone took appart the x100F?
Thank you
Neven
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I took both cameras apart and removing the bottom plate of the X100F is way easier than with the X100T. You just need to remove 5 screws in the bottom. One at the battery compartment and the four remaining ones on the opposite side – leave the two at the tripod mount where they are for now. You can then remove the bottom plate. If you need you can unscrew the tripod mount to move it to the new bottom plate.
Since your post has been here for a while this might not be of interest to you anymore, but maybe it is helpful for somebody else in the future ;)
Cheers
Chris
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Hello Chris, thanks for you answer. I did found someone who made the replacement but still I am sure that one more screw must be removed, the one on the side of the camera (the one with the focus selection lever. Please verify it, so people do not wonder about it, if they have to do it.
Cheers
Neven
Puan 0
2 Yorum:
My apologies, I suppose you are right, Neven. I will remove the bottom plate in the evening to verify. Maybe I take some pictures and post them here.
tarafından
Hi Chris,
Have you had a chance to verify it?
Thanks,
M.
tarafından
Yorum Ekle
How do we buy a replacement base plate?
Puan 0
1 Yorum:
I am selling mine. It has slight marks on it (that is why replaced mine.)
tarafından
Yorum Ekle
Yanıtını ekle
Neven Miškulin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 37
Her zaman: 1,293
