Which way does the fan blow?
Does the fan in my laptop draw air in or blow it out?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Your fan should blow air over the heatsink to help it dissipate the heat from the processor. It will draw air in>over the heatsink> and then out.
Bu yanıt yardımcı oldu mu?
i bought a cooling pad you put it onway if your fan blows or flip it if your fun draws air in
still not sure which way to use it.
michelle, the cooling pad should force more fresh (cool) air up into the computer. Since the laptop sits on it, a fan could not draw out any hot air. They do just increase airflow. Always make sure that you have the laptop slightly elevated,especially if you use it while laying down etc., so that you have unobstructed airflow.
thank you so much.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 1,722
