Ana içeriğe geç
Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Soru Tümünü görüntüle
After ssd change, the trackpad doesn’t click
After ssd change, the trackpad doesn’t click, and I cant choose disk utility because of it, also Enter doesn’t work! Could anyone help me with this issue? I have Mac OS El Capitan, the ssd I was changing to is Samsung 860 evo 500gb
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
I would first make sure the Trackpad cable is fully seated into the logic board, maybe it got bumped during SSD replacement and got knocked loose.
If that doesn’t work you can try adjusting the trackpad tension screw and see if that helps. You’ll need a T6 to do this. Make a half a turn, place laptop in upright position and then test the trackpad. If it’s not clicking properly make another half turn and test it again. If you over tighten this screw you can break the trackpad so be careful.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Ryan thank you for your reply,
Fortunately enough, I was able to solve my issue using voice assistant throughout reinstalation process, once I was done, I simply recovered my previous settings and it worked as before,
Thanks again for sharing, hope someone will find your reply useful!
tarafından
Yorum Ekle
Yanıtını ekle
Адам Хачилаев sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 57
