Ana içeriğe geç
Google Pixelbook Go, minimalist tasarımı ve dayanıklı magnezyum kapaklı kasasıyla Google'ın üst seviye Chromebook'udur. 2019 yılında piyasaya sürülmüştür. Model numarası: GA00521-US.
Re-insert clamshell pin into hinge
Resim
One end of the hinge on the Google Pixelbook Go has slipped out of place. I do not know how to reinsert it. The two pieces of the clamshell do not feel flexible enough to bend and allow the pin to slip back into the hinge.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
4 Cevap
Filtre ölçütü:
Curious what you ended up doing here. Your issue (and mine) is that the hinge itself is broken. This is caused my the screws loosening causing a torsional flex in the hinge when then snaps it.
The screws loosen over time due to hinges being too tight.
Google isn’t supporting the devices and there’s no way to get replacement parts.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
TL;DR Don't buy Pixelbooks.
I returned the broken Pixelbook to the seller and got back 80% of the purchase price. The money I got back was enough to buy two Lenovo Chromebooks w/ 8GB and touch screens.
tarafından Paylaş
I have the same Pixelbook AND the exact same issue. I have another problem as well, when the right hinge is lowered, the display goes black, everything still works, the device isn't turned off, I believe it might be a severed display cable
tarafından Paylaş
Yorum Ekle
It seems that the hinge is snapped from the image. Could have happened when the LCD is accidentally pushed exceeding the limit. Can be fixed by removing the back cover and swap out the damaged hinge.
Puan 0
Yorum Ekle
I was able to buy a hinge on eBay (at outrageous price for such a small element) and replace it, otherwise you can replace the whole unit for $$$.
Puan 0
Yorum Ekle
@piotrkaminsk163 How did you replace it?
Puan 0
Yorum Ekle
Yanıtını ekle
Aaron Hoffer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 1,629
