timing chain position on sprokets
I have a 2001 Pontiac Grand Am 2.4L 4 cyln. Where to set the timing chain if its out of place?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Here is a diagram the shows you how it is all setup. Just wondering if you have ever done this kind of work before. It is very involved and not quite as easy...
Bu yanıt yardımcı oldu mu?
+ And if you get wrong you could destroy the engine. I usually change the water pump at the same time--you have to remove it to get to the timing chain. And double check the sprockets.
may I have that diagram too. thank you
@draccocain Carson, Dom, Below is the 2.4L 4 cyln. timing diagram. Good luck.
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 3,510
