After "copy" "paste" the hardrive does not working anymore
I just bought a hardrive. I plugged it, copy paste some file. The transfer didn’t finish. It gives an error and now it does not work at all. (see an example)
Notice : I’ve already done some scan and try to find the hardrive through the windows built-in options or with another program called “AOMEI Partition Assistant” but it does not appear.
I also used wd elements scan program. It cannot do anything because of there are too much blocks error.
Bu iyi bir soru mu?
8 Yorum
Hi @kevin07
if you had tested with another computer and it is also having the same issues, e.g. read / write issues, try sending back for a exchange / repair
Augustine tarafından
The seller does not respond when I try to contact him.
Kevin tarafından
@kevin07 Whered uou buy it from? if its from ebay, give them a call, they can help you
Dylan Devries tarafından
No that was from aliexpress.
Kevin tarafından
@kevin07 oh. I’m not entirely sure how that would go down then, as Ive never bought anything from aliexpress
3 tane daha yorum göster
