Ana içeriğe geç
21 Eylül 2018'de piyasaya sürüldü. A1921, A2101, A2102, A2104 Modelleri vardır. GSM veya CDMA / eSIM veya nano-SIM / 64, 256, veya 512 GB / Gümüş, Altın, ve Uzay Grisi seçenekleri mevcuttur. ("iPhone 10 S Max." olarak telaffuz edilir)
375 Soru Tümünü görüntüle
Phone restarts after 5m and is very slow after battery replacement!
Hello, I had a iPhone XS Max which needed a battery and dock connector replacement, but now the phone powers on but is extremely slow and restarts every 5 minutes. It doesn’t show the percentage of the battery as well… I ordered the battery for €40 and the dock connector for €15. Any idea what the problem could be?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
iPhone XS and XS max series have a serious problem. First, see the panic log from setting/privacy/analytic and improvements/scroll down and search for the panic log on which you got an answer. The various region among them ear speaker flex and charging flex, power switch flex may cause that problem. If you try this and you got such a problem still the same this tutorial helps you.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Hey, thanks a lot for the tutorial. I think it is indeed the charging coil, becaus I overheated it with my heatgun... So I will replace that
tarafından
Yorum Ekle
Yanıtını ekle
Ingmar Prins sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 552
