Ana içeriğe geç
2, 2.26, 2.53, or 2.66 GHz Core 2 Duo processor
106 Soru Tümünü görüntüle
Apple Install Disk versus Ubuntu EFI
Trying to upgrade the disk in the mini I ran into a problem. It seems that if Ubuntu is installed first, the Apple Install disk isn’t even seen as a bootable disk. Using Alt to invoke the boot manager, only the Ubuntu/EFI partition showed. Just as a band aid I grabbed a new disk and installed it. Then the Apple Install was bootable and the install went smoothly.
How do I get rid of the Boot Manager Ubuntu installed so I can put Apple OS on that disk ? Now if I had a drive enclosure then I’d put it in there and use Disk Utility, but I don’t. Nor do I have a two disk system except an older Mac Pro that might run OS 9.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
You will need to reformat the drive fully as I outlined in your other posting: How to reformat an SSD?
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
James Walker sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 84
