Yoga 900 will not start unless I disconnect and reconnect the battery
I replaced the battery on the Yoga 900 ISK2… and now the notebook only starts after I disconnect and reconnect the battery after shutdown. This is true only for shutdown situation. Sleep and wake from sleep works. It is the same situation when connected to power or not. I also tried putting back the original batter and same behavior.
Here is it in order:
- connect the battery - I can start the notebook pressing on the start button
- reboot works… will reboot without a problem
- shutdown works… but the I can not start the notebook again… the button to start will not work
- physically disconnecting and reconnecting the battery… I can start it again via the button
All cases I found with the same behavior (and other notebooks) did not have an answer.
Any hints what this could be?
Bu iyi bir soru mu?
