Ana içeriğe geç
2, 2.26, 2.53 veya 2.66 GHz Core 2 Duo işlemci, DDR3 RAM kullanır. Grafik işlemcisi, takılı sistem RAM'ine bağlı olarak 128-256 MB VRAM'e sahip FX9400'dür.
How to disable HD temperature sensor Mac Mini 2009
I just broke off the temperature sensor cable of the HD SATA board when putting in an SSD. It really looked like a spudgeable thingy, yet it wasn’t.
The sensor should be no longer relevant, but the system now thinks it is a Nuclear Power Plant core and turns the fans to a zillion RPM.
So my question is: how to fool OSX to think this sensor IS NOT THERE in the first place, and taken out of the equition to calculate the fan speed. No problem to Hex Edit some kext files.
Options I consider no solution are:
Installing MacFanControl. I did that, it helps a tiny bit, but only from 10 seconds after boot.
Connecting the 2 pins on the SATA board with some conducting material. It does not work.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
I would just replace the damaged board Mac Mini Interconnect Board - HD/Optical (09), Apple P/N 922-8807
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Blanka sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 451
