Doesnt switch gear, any help?
Doesn’t switch further than 2
Bu iyi bir soru mu?
Assuming it’s a manual transmission, have you checked the shifting linkage to make sure it’s not broken right? If you are using the clutch and it’s shifting into 1 and 2, seems that the clutch cabling is engaging fine.
This is just an example of bushings worn or the cable out of alignment: https://mercedessource.com/problems/tran...
Basic troubleshooting for you to do:
https://axleaddict.com/auto-repair/Manua...
Next time, check those first before posting as people will want photos and such. Also state the type of transmission as that’s extremely relevant to troubleshooting/diagnosing.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 56
