It appears that your console is parental locked. You can call Nintendo but that takes time so I’d suggest you use this procedure instead:
- Go to settings and see if you can get the parental controls prompt to pop up
- Choose forgot password on the bottom of the keyboard
- In the security question, choose forgot again
- Make a note of the Inquiry number
- Go to https://mkey.salthax.org/
- Choose 3DS
- Put the current system date (in case it’s wrong or something
- Leave Additional Data empty
- Put the number you made a note of above in the Inquiry Number field and hit Go
- Take the new number and put it on the number field on your 3DS
- The console should now be unlocked, go to the parental controls menu and disable it fully.
I hope this helps! If you have any questions feel free to report back (pictures of your screen are preferred so the community can understand better.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
did you ever find a way around this? my 2ds has just done the same thing and i haven't got a scooby doo how to bypass this pin
haydentcity tarafından
Hi, i did provide an answer below a long time ago, let me know if it works for you.
Devnol tarafından
@devnol the issue is i can't physically access the ds to get to the settings, it's literally bricked on the "enter pin" screen even tho i have no idea what the pin is, it's a 6 digit combo with abxy and the dpad
@haydentcity Oh, i'm sorry. Black screen means your console has a pin set from some homebrew app, probably Luma3DS. I don't have a 3DS to test right now but either the NH Discord (at 3ds.hacks.guide) or the r/3dshacks subreddit will definitely be able to help.
Devnol tarafından
