Ana içeriğe geç
Released September 20, Apple's flagship 2019 smartphone features a 5.8" OLED display, a triple-lens rear camera, and greatly improved battery life. Successor to the iPhone XS.
150 Soru Tümünü görüntüle
Display is always dimmed
Has anyone seen an iPhone 11 Pro display that is very dimmed? It has around 1/3 brightness compared to my own iphone 11 pro max when I set brightness on highest.
I reset the user settings to be sure it wasn’t a setting. The disply is already dimmed when you see the apple logo when booting.
the phone was dropped and I replaced the backcover and cameralens on it.
When I put another refurbished i11 pro display on it the brightness is fine. Have not seen this before on an iphone OLED. Faulty screen after drop I think but asking to be sure if anyone has experience with this.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Since you already troubleshooted with another device, the problem clearly seems to be in the screen or in the components attached to the screen. Brightness is controlled by the ambient light sensor in the screen, it could be that this sensor is damaged and it’s sensing “darkness” so it would dim the brightness of the screen backlight to not blind you while being in the dark.
If you’re up to it you can try to swap those two parts of the screens you have and see if that fixes the problem.
Have a look at step 26 of the iPhone 11 Pro screen repair. Note that this will require you to swap out the whole speaker & sensor assembly of the screens.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
The components don’t matter in this repair. The sensor has nothing to do with how bright a display can be at max. The screen has problems that I haven’t seen before on an iphone oled. Thought it was strange. Swapping it solved it.
tarafından
Then it might be a LCD driver issue or some kind of other damage that isn't to be seen with the naked eye.
tarafından
Yorum Ekle
Yanıtını ekle
KWH sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 147
