After upgrades still runs like crap
Upgraded the hard drives upgraded the RAM replaced the logic board after I spark it putting in a new battery like a jerk, still runs slower than molasses ran clean my Mac X & still is giving me issues. Only runs great in safe mode but I Don’t have access to certain functions.
and it’s worth noting that it took three years for the logic board to become available in that time I only ran the computer on safe mode so when I replace the logic board I wiped the hard drive to start with a clean version of High Sierra but it was a nightmare trying to load it from the Mac mothership. Anybody have any suggestions? Oh yeah and the cursor just stopped working I have to use an external mouse
Bu iyi bir soru mu?
11 Yorum
Well I would first run the onboard diagnostics to see if any errors popped. Restart the system and press the D key. Let us know what you get for errors.
Reference: Mac startup key combinations
Review this Your Hard Drive Cable Is A Ticking Time Bomb a common issue is a worn or damaged HD cable.
Dan tarafından
Ok will do - any Ideas as to my the cursor suddenly stopped working? I replace the trackpad and it’s still not working should I replace the trackpad cable?
David Curran tarafından
@dacnjnc - Once you get the diagnostics output it should give us some ideas which way to go.
Dan tarafından
Ok, running diagnostic now
Also a HDD won't be as snappier as an SSD but that's another topic.
Dan is on the right path for you to run the AHT (Apple Hardware Test) now called Apple Diagnostics to check for error codes BEFORE the OS is started. Seems like there's still an issue after you replaced the board.
DunCanP tarafından
6 tane daha yorum göster
