Item number for ac power adapter replacement.
Replacement for ac power adapter.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
For this laptop, I cannot find an adapter from HP on their website, so the OEM adapter may be “EOL” at this point. For this model, you may need to settle on a used OEM adapter. The HP Spare# is 239705-001.
I’m not going to make any recommendations on where to buy it, but what I would do is take the Spare# and check sites like eBay for it specifically. You may need to supply your own power cord, but the brick shouldn’t be that expensive. They tend to go for $10-20 on eBay, new or used. The reason they’re so cheap is because of the amount of dead nVidia units vs. working power adapters - the adapters outlive the bad GPU here. What that means for someone with a good GMA unit like yours (which didn't break so bad it ends the machine's life) is you can get cheap adapters that are known to work whereas the notebook died, and for cheap :-). They’re just trying to sell off the adapter, so you can get a cheap replacement without looking too far.
But just make sure you don’t spend a lot on this laptop - it’s a factory Vista system from 2007. It probably only still works because it’s not one of the nVidia units, which are all dead, or one heavy load on the GPU from it.
Bu yanıt yardımcı oldu mu?
Hi, I found the Charger for Your Computer I will put the link below!
HP Pavillion Dv2000 Power Adapter:https://www.amazon.ca/Adapter-Supply-Cha...
Downvoting due to recommending a knockoff adapter. These kill laptops!
Yes, the DV2000 is still a 2007 Vista era HP (old and practically worthless), but this is still a BAD recommendation over even a used genuine adapter. It can kill the hard drives if it fries multiple parts, so if the adapter blows up it may cost them their data as well as the motherboard!
At least with the HP adapters the odds of not blowing up the drives if the board gets trashed is low and they can get a USB enclosure to get the data back.
I personally scrap these without a second thought due to their age if they have an issue with a major component, motherboard (bad GPUs), hard drive failure (SATA I/II era. I think these use the SATA I Option ROM, if the northbridge is even SATA II compatible) or WLAN card (WL issues), but I wouldn't even recommend anyone who still uses them buy a knockoff because of the high risk of damage. I don't deal with them all that often anymore, thankfully - most of them have had expensive issues that put an end to the machine being in use.
Sorry I couldn’t be much of a help!
@stevejob20084 Just educating you on why 3rd party adapters are so bad... They destroy machines.
I've seen it a few times. It's not fun.
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 137
2 Yorum
Have you got the old AC Power Adapter? Just read the specifications printed on it, in this format 19.5V 3.33A 65W. You'll usually find it down at the bottom just above the serial number. Most large computer shops have many HP AC power adapters.
Just don't buy cheap "knock -off" ones.
mike tarafından
@aactech You can use the 90W ones from the dead nVidia units too - same tip voltage, and they're easier to find.
Way more because of the death count caused by the bad GPUs... Also the reason I scrap the things when they have an issue, GMA or nVidia.
Also the computer shop tip applies with a lot of HPs - the adapters seem to outlast the computers a lot more often than I care to admit.
Nick tarafından
